Спортен филтър?
- Japanese_fever
Re: +
Punky pri kakvi oboroti na dvigatelq gore-dolu lMAP sensora zapo4va da raboti na open loop(otvoren cikul na rabota)? Za6toto maksimalna skorost e malko otnositelno ponqtie . Az naprimer, ako sloja takuv filtur konusoviden i karam sus 80-100mph, koeto e malko pod max skorost za moq dvigatel, MAP sensora 6te raboti li na open loop ili o6te ne?punkara написа: ti nyamash debitomer, imash vakumen MAP sensor. Tvoeto ECU pri maksimalna skorost prehvurlya na otvoren cikul na rabota, toest ne slusha lambda sondata, ami si chete gotovi cifri za kolko bensin tryabva da vpruskva, s toya filtur shte vliza poveche vuzduh ot izchislenoto toest shte se obedni smestta, i shte sa kachat temperaturite v cilindrite, i togava e vuzmozno da izgorsh klapan, ili da ti izgori svesht, i da padnat chasti ot neya v cilindura, i posle veche stava losho... pone slozi po topli sveshti! ot tip: Champion RN7YCC naprimer!
dano nikoga ne stava, no go imai vpredvid!
I o6te edin ?:
Pri vkliu4en cruise control MAP sensora pak li raboti na open loop sled kato kolata podurja edna i su6ta skorost ili produljava da priema danni ot lambdata?
Blagodarq predvaritelno!
Tova li e MAP sensora?:
Manifold absolute pressure sensor - Monitors the pressure of the air in the intake manifold.
The amount of air being drawn into the engine is a good indication of how much power it is producing; and the more air that goes into the engine, the lower the manifold pressure, so this reading is used to gauge how much power is being produced.
Re: +
map sensora, ne vkliuchva open loop, toi si meri... tazi informaciya idva ot TPS sensora, kogato e otvoren napulno, toest full trottle, i togava veche ECU to prehvurlya na open loop.
- Japanese_fever
Re: +
Da be az iskah da kaja open loop na ECU-to, ama se oburkah?!?punkara написа:map sensora, ne vkliuchva open loop, toi si meri... tazi informaciya idva ot TPS sensora, kogato e otvoren napulno, toest full trottle, i togava veche ECU to prehvurlya na open loop.
Razbrah ve4e.
