Towa e specifikaciqta na British Touring Car Championship Toyota Carina E. Interesnoto e, che dwigatelite qwno ne sa turbinirani (sled kato sa GE?). Kakwo predpolagate e dowelo na 300 konq?British Touring Car Championship
Toyota Carina E Specification
ENGINE
Designation: 3S-GE
Type: Water-cooled, in-line, 4-cylinder,
16-valve, DOHC
Bore & stroke: 86mm x 86mm
Total displacement: 1998cc
Engine management Zytek multipoint, sequential and
system: programmable fuel injection
Power output: Around 300bhp @ 8500rpm
Maximum torque: 220 lb/ft
Lubrication system: Dry-sump with oil reservoir located
in engine bay; Mobil 1 lubricant
BODY & CHASSIS
Dimensions: Height : 1410mm
Length : 4530mm
Width : 1695mm
Wheelbase : 2580mm
Track - front/rear: 1455mm
Kerb weight: 975kg
Fuel capacity: 60 Litres
Transmissions: Xtrac sequential box, six forward
speeds and reverse; quick change dog-
engagement gears
Clutch: AP racing clutch, hydraulic operation
Suspension: Toyota Super Strut front, MacPherson
strut rear, coil springs, heavy-duty
hubs
Brakes: Brembo racing callipers with 14"
ventilated discs; Mobil brake fluid
Tyres & wheels: OZ magnesium-alloy racing wheels, 18"
or 19" diameter with Michelin 210/650
racing tyres
Instrumentation: Toyota Measurement System (TMS) data-
logging computer with programmable data
display
Press Release issued to "Racing Into the Future"
Courtesy Paul Risbridger, Toyota Team GB Team Manager
British Touring Car Championship Carina Specs
От това може смело да си извадиш изводите че е с валове, вероятно 300 градусови (понеже си е пистарка), степен на компресия поне 11.5 и балансирани и олекотени елементи по мотора. Въртящия момент определено не е на нивото на турбо-моторите 2.0 Тойота.Power output: Around 300bhp @ 8500rpm
Потребители разглеждащи този форум: 0 регистрирани и 41 госта
